Hi,
I have a 1993 Eunos with a small box bolted to the side of drivers leg compartment
Does anyone know what it is and what it does please?
Camerart
Hi,
Camerart
I think its meant to be an illuminated shift pattern,
Razo is a brand of Carmate, which is sort of like a Japanese Halfords. So I suppose like Ripseed.
Normally a Razo gearknob is accompanied by a little stick on plate, similar to yours, and most owners attach it to the centre console
Hi S,
Is it supposed to tell you what gear you’re in?
I don’t think mine lights up, but as the radio also doesn’t work, I assume they are both connected and will be sorted out.
Thanks, C.
Pretty sure with just two wires it wont tell you what gear you are in.
Hi S,
So it looks like they just tell you where your gears are in the dark
Thanks, C.
