1998 NB Specifications
Obviously, not enough development. Its not uncommon for X350 owners to have to replace theit 2005 rear subframes due to proper, deep, rot. My tank straps are looking a bit twig like. I’m hanging on for someone to produce stainless steel versions; Jaguar jacked up the price of these straps fro  £25 to over £100 over  night
Broken 10p earthing studs is very common. Owners shopping in B&Q came up with a better solution than the Whitley engineers.
As a kid growing up in the middle east, dad had a clapped out Range Rover (no roads), which had a non-functioning London installed aircon. Blocked drain on that managed to cause the passenger floor to fall out… Aluminium body on a steel chassis, like every other proper land rover. No issues with electrics on that, as I suspect everything was earthed back to the steel frame.
Eddie, I’ve sent you a PM with the details.
Not my problem although you can be forgiven for assuming it was. I was an IT contractor at the Jag, no direct connection to engineering decisions that may or may not have been the best.
Surely the tank straps are suffering standard corrosion not galvanic. Apparently some stainless steel, the lesser grades as I understand it suffer more with galvanic corrosion than mild steel.
The sacrificial anode on the Land Rover is obviously the chassis, galvanised or not.
In retrospect most cars have a long list of poor engineering decisions. The persons who designed/implemented MK2/MK2.5 front chassis rails deserve a good kicking. I don’t think B&Q stock a solution for that. Generally speaking the beauty of the MX5 is a lack of poor engineering decisions making ownership that much more pleasurable.
Helen,
Thanks for providing your 10AE VIN number.
According to the Mazda parts listing.
The 10AE has
A standard front antiroll bar and bushes.
A rear antiroll bar and bushes suited to hard suspension but the metal rear antiroll bar bush cover and drop links are standard.
Hard suspension front and rear springs and dampers.
A six speed gearbox.
No aircon, the 10AE had in some but not all markets. OTOH not all markets got the model car and the his and her watches that the UK buyers received.
Gerry it appears the NB Sport was based on the 1.8iS with addons.
I would assume it has the Sport front springs and dampers rather than the standard front springs and dampers.
I drove a Mk2 1.6 after changing the cambelt two years ago or so and while both cars had around 100k miles on them, the standard springs and dampers that the 1.6i had appeared to make no difference to the handling or ride compared to the 1.8iS.
100,000 miles on both cars would tend to soften the suspension over the years.
I have no idea who supplied the Sports dampers and Springs to Mazda.
