I have a 2002 JDM MK2.5 automatic.
I’m considering having a 4 - wheel alignment done, using the numbers from a Flyin’ Miata post on this forum back in 2018. (Basically fast road use)
The question I have, and cannot find answer to, is should these settings be done with a person/driver seated in the car at the time of adjustment or not?
Logic to me is settings may be fine with vehicle unloaded, but will change as soon as someone gets in the car!! What do people do with cars setup for track use??
Proposed settings by the way are : Caster : 5 degrees Front Camber: - 1.0 degrees. Total toe in 0.15 degrees Rear Camber : -1.5 degrees. Total toe in 0.15 degrees
Comments/advice/recommendations gratefully accepted
