91 Greddy kit turbo/manifold gasket
Hi all,
Sorry for asking the same question as I asked about 2 years ago…
I need a gasket for my Greddy turbo/manifold , does anyone know the Mazda part no. for it ( it believe it is the same as another model). I know someone does as I got the info from here a couple of years ago and stupidly didn’t order 3 from Mazda!
Blew another one today.
Cheers -  Paul
From the old forum
TDo4H Turbo gasket - Any ideas?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.
   UK MX-5 Owners Club Forum Index -> Modifications - Performance/Supercharge/Turbo -READ ONLY- View MX-5 related posts since last visit
View previous topic :: View next topic
Author Message
CountvonC
MX-5 Club Member
MX-5 Club Member
PostPosted: 17 Jun 2006 08:16    Post subject: TDo4H Turbo gasket - Any ideas? Reply with quote Edit/Delete this post Delete this post View IP address of poster
Hi Chaps,
I need a set od metal gaskets for my GReddy which has a TDo4H turbo.
Has any one sourced these in the UK?
I just need them in a bit of a hurry. I will have a ring around on Monday, but just wondered if anyone had any ideas before I do that.
_________________
Regards - Paul
OC member: 3***
with added GRRRRReddy
Back to top
View user's profile Send private message Send e-mail <!--
if ( navigator.userAgent.toLowerCase().indexOf('mozilla') != -1 &amp;&amp; navigator.userAgent.indexOf('5.') == -1 &amp;&amp; navigator.userAgent.indexOf('6.') == -1 )
	document.write(' ');
else
	document.write('</td><td>&amp;nbsp;</td><td valign="top" nowrap="nowrap"><div style="position:relative"><div style="position:absolute"></div><div style="position:absolute;left:3px;top:-1px"></div></div>');
			//--></script>
lloydie
'B' Road Blatter
'B' Road Blatter
PostPosted: 17 Jun 2006 10:05    Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
The turbo to manifold gasket you can pick up at Nissan, part number 14415-17M00 for a 300ZX - about £12. Cant help you with the other as thats the only one i had to replace.
_________________
1990 Eunos track toy - FM 1.9L engine with forged internals, '99 head, AEM coil on plug ignition, Hispec big brakes, Motec M4 Pro ECU, 6 speed, 4.1 Torsen
Back to top
else
			//--></script>
CountvonC
MX-5 Club Member
MX-5 Club Member
PostPosted: 17 Jun 2006 15:54    Post subject: Reply with quote Edit/Delete this post Delete this post View IP address of poster
Brilliant - Thanks!
_________________
Regards - Paul
Thanks, and do you know I looked for that before I posted… your search skills are better than mine. Cheers - Geoff!
Paul
 It depends who you ask but many advocate not using any gasket between the turbo and manifold, if it isn’t there, it can’t blow it !
 Yeah, good point! It seems to be the only weak point on my set up.
 Have a read up but I was surprised when I took an AVO turbo kit apart not to find one and then I found out that many advocate not bothering, including Corky IIRC.
Providing the mating surfaces are machined flat and are in the correct alignment, then you could get away with a smear of exhaust gasket cement. I worked on a Massey Ferguson Turbo tractor a few years ago and discovered that all Massey tractors leave the factory with no gaskets on the machine. All  the joints are made with the appropriate hermetite jointing compound.
I need one of these too, but also I need an engine to manifold gasket. Would that be the standard non-turbo part?
That’s certainly what I use and have never had a problem.
