I’m looking for technical help or recommendations on: ABS fault light
Hi there, I am trying to fault find on my NB. The ABS light is on but the ABS seems to work so I am assuming it is a faulty sensor.
I would like to know how to diagnose which sensor this is. I thought I might be able to use an OBD2 scanner but that doesn’t seem to be the case as there is no port next to the fuse box where google says it should be on a MK2/NB.
There is a port in the engine bay (passenger side) that you need to bridge two holes and the dashboard then blinks and gives you a code to lookup…https://m.youtube.com/watch?v=-xIj2Ouweho
