Hi there,
I’ve just swapped the original cloth airbag seats for second hand airbag leather ones on my 7-plate NC and I can’t work out how to rectify a fault with the airbag warning light. The light comes on when the engine is running and flashes. Help will be appreciated in rectifying!
Thanks,
Nick
Look at how the light is flashing.
It should be doing long flashes and short flashes.
EG 2 long flashes plus 2 short flashes is code 22
Code 12: Low Battery Voltage
Code 13: Airbag circuit shorted or grounded
Code 14: Primary crash sensor circuit short/ground
Code 22: Often related to the passenger occupancy sensor (POS) or passenger seat plug
Code 33/34: Driver (33) or Passenger (34) seat belt pre-tensioner
Code 48: Passenger side airbag circuit or sensor fault
Code 19: Circuit resistance low/open (often seats out)
