- My model of MX-5 is: 1995
- I’m based in: Greece
- I’m looking for technical help or recommendations on: locating an ambiguous metallic rattle — passenger side
Hi everyone,
I’ve got a persistent rattle that’s been driving me crazy and I’m hoping someone might have an idea or two.
The sound: Best way I can describe it is two metal shards or shims vibrating and clinging together — almost like two pieces of sheet metal kissing at road frequency. It’s clearly metallic, not a bush or rubber sound. The sound is there with both the hood up and down. It is not like a small fastener or clip has fallen into the body structure, it’s more like a welding has come loose and the metal surfaces tap against each other.
Location: Seems to originate somewhere on the passenger side rear — the seatbelt/B-pillar area or along the rain rail area but on the non-visible side between the outer fender and the car body. It’s probably somewhere high in the body - think of it close/behind the rain rail.
What I’ve already done:
- Replaced all bushings underneath the car. Also, the hood has been replaced at some point in time.
- Checked the boot — antenna mechanism, spare tire - everything seems solid
- I removed the passenger’s seat, rear deck carpets, the seat belt retractor mechanism, emptied the trunk completely. A few cables in the trunk were here and there and were tapping to metallic surfaces, but that wasn’t the problem. With these things removed a can hear the noise clearer.
- My mechanic has been looking into it and tried using a sort of stethoscope and the noise seems to be somewhere in the non-visible area behind the rain rail/read fender but still can’t feel it/access it by hand, which would make it stop and we could locate it.
I noticed there are openings from the inside of the car to several cavities in the rear fender, but this is a place I can’t access (thinking of getting even an endoscope camera with a magnet and LED light but I fear that the movement of the metal will not be that visible).
I found the following pic and I’ve circled the suspect areas.
Has anyone faced something similar before? Any tips to access these areas or how I could spray some kind of “grease” that would make the noise milder?
