Could anyone tell me if a MK2 air con radiator fits in the MK1 ?.
The later Mk2 condensers have different mount points to Mk1 I can’t speak for early Mk2 ones as I’ve never dealt with one.
Thanks for that info .much appreciated
The parts list on the Mazda European Portal that Mazda UK allows non Mazda approved repairers to access, shows no Air Con radiator or fittings from 1998 to 2005 covering the Mk2 and Mk2.5. It does show the second fan with all it’s parts numbers and most of the cars have wiring already there for the second fan.
We do know that the 10th Anniversay cars in hotter climates came with air conditioning.
Therefore the best idea is to find parts lists from the states or say Austrailia and try to check parts numbers. Otherwise a post on Miata.net may well help with this search for information.
Cheers drumtochty getting a one is like Rocky horse pap.
I was wrong here. The cooling system parts do not show the airconditioning parts.
Further investigation shows that if you search under, body, air conditioning and ventilation.
The radiator or condensor has a parts number N053-61-480D with the 2003 on cars having a parts number N053-61-480E
This is a picure of the unit used stateside that may or may not be identical.
On ebay
I think i have one sorted hopefully but thanks for info anyway m8.
