I am in the US. We never got the level-adjustable headlights here. So I bought a set from the UK and had them shipped over here because I wanted this option. I took them apart and converted the beam pattern to one legal here but I didnt get any connectors with the lights and switch(lesson learned, dont assume that because an Ebay pic shows connectors that you receive them). So I took a trip to the junkard and found some Toyota Landcruiser parking light connectors(they fit the motors oddly enough) and some connector from an 01 Mazda Protege that I was abld to make fit the switch with just one little cut..so far so good…but now my problem is that none of my wire colors are what they should be. I have a Haynes wiring diagram for the circuit but it doesnt show the connector shape so I cant tell which pin corresponds to which wire. So I either need a wiring diagram that shows the connector pinout or more simply some pictures of the wires going into the connectors so I know what to connect where. Any help is greatly appreciated
A bit TMI but the workshop pdf is here. I’m using an iphone so couldn’t scroll down for an hour to find if the diagram you need is there but fingers crossed.
Very good repository of wiri g diagrams and other manuals. Sadly it seems this circuit does not exist there? I think after hours of google searching image I may have found enough info combined with the Haynes manul to make an educated guess.
Do you want the wiring diagram for an NA or NB?
