Bought this strut brace for not much monies. But it has no brackets. Anyone know what it is and what brackets I’ll need?
Its not a strut brace. Its the factory cockpit brace fitted to the 1.8 Mk1, and missing its end caps. On a 1.6 Mk1, under the seatbelt trim, you will find a hole you can use, but its not tapped, so you need a nut and bolt to fit, fitting the nut on the inside of the tower (you need a socket and extension. Then you need to cut the plastic trim to fit it.
Oooh was not expecting that haha. I’ll give that a go, thanks for reply!
