The MK3 has a ford(Duratec) engine I think. As well as cam chain, rather than belt this engine is interference, so a broken chain will impact valves and pistons.
MK3 towbar may be available from the states or get one fabricated.
The timing chain has an automatic tensioner and should last for the full life of the engine. There’s nothing in the service schedule about replacing it.
PS The engine is actually a Mazda MZR engine, not a Ford design, though Ford have the rights to manufacture it as a ‘Duratec’.
Its Interesting that if you use the USA link for the Towbar and in the Car make and model box, for model it gives a choice of MX5 Miata or MX5 if you choose MX5 it states the Towbar is NOT suitable for this model
Without searching I can’t be sure, but I recollect reading something about MK1’s being fine with a towing bracket but “illegal” on later models? It was on MX5Nutz that’s for sure, some while ago. Makes some sense where the USA will have different legislation I suppose? Don’t ask me why it would be illegal, I’ve no idea.
Over the main drive belt it is a chain. The belt you see is the Aux belt, it is not due for replacement in any service schedule at all.
But…(there always was going to be)…
Whilst I have never heard personally of the aux belt snapping it does drive the water pump for the engine, so if it snaps there is going to be lots of crying. Also it is worth considering replacing the idlers & tensioner whilst it is off.
There has been some issues (common among the MZR engine range) of the automatic tensioner…
