The battery in my 1.8 NB wasn’t very old and had no issues, but to be on the safe side when I put it away for the winter I attached it to a solar battery conditioner. Only a couple of weeks later I went to use it and the battery was completely flat. I removed it and it wouldn’t charge on the bench, neither could I jump it. Bought a new battery which I know is charged but still nothing (not even a click, no lights, totally dead). Have checked main fuse and its OK so am now stumped, any ideas guys?
If nothing works it’s not immobiliser related. Unless it’s had an aftermarket thing added… I’d still be surprised if an immobiliser cut the whole electrics.
Yeah thats what I thought. The immobiliser is standard, I wonder if there is another fuse somewhere, I did see this mentioned online but it wasn’t clear what model of MX-5 they were talking about.
I think you might be refering to the window and central locking fuse behind the trim panel above the battery in the boot. Worth checking to see if it is okay but unlikely to be the cause of your dead electrics.
Yes its completely standard. A couple of months ago the battery in the keyfob went and following the advice on here I was able to pair the fob again so it seems like a normal NB.
I will do later. But as I say it was 100% OK when I parked it two weeks ago so whatever has happened has been caused by the solar powered battery conditioner. Baffled.
Or something has gone wayward during the battery disconnect/reconnect/replacement. We need to ascertain why the 12 volts from the new battery is not making its way to anywhere on the car.
How certain are you that the main fuse really is OK? You could also check for voltage at some other fuses.
Have you tried the original battery back on the car? The one that was working without problems, which you took out in favour of a new battery.
Which battery did you choose for the replacement?
I’ve always stuck to the recommended, ie., Westco.
Fitted with an isolation (screw) switch to the Westco battery (with breather pipes), to prevent draining energy to maintain ECU etc.when not on charge.
