Hi all. My 2011 Kendo has a fault in that the fob for the central only operates the drivers door. All was good up until a couple of weeks ago. Anybody Experienced this and have a quick easy fix?
Only had the Kendo about 6 months but use everyday and love, even get the golf clubs in with roof down.
Could be the door lock actuator, the drivers side can be the one that fails first, more use. I replaced mine with a secondhand unit but can be had new from the dealer.
Try the simple first, the passenger side isn’t sticking somewhere, is it working if operated manually?
Yeah I had that had to replace the actuator around £30 on eBay and less than an hour to fit yourself.
They are sided so ensure you get the appropriate side.
