tonygw
19 February 2009 13:41
2
Hi Guys
I will be helping a friend change the front hub / bearing on his 1999 MK2 MX5 this weekend
Never done one before so was just after any tips you guys could give before I start.
I’m thinking remove brake pads -easy
Remove caliper completely - straightforward
Remove brak disc - no probs
Then I’m guesing remove dust cover and crack the 210Nm bolt holding the hub in place.
Will it then slide off or have I missed something?
Tony
That’s about it… I’d leave the caliper built up and just undo the 14mm caliper bracket bolts and remove the caliper complete. You may have to wind a bolt into the disc to pop it off. Do you have the correct size socket for the nut? (29mm) and do you have a new stake nut?
tonygw
20 February 2009 09:10
4
Thanks Robibe
I think I will leave the caliper built up as you say then.
I ahve the correct size socket, 29mm (black impact type) So am ready to give it some jip LOL!
Whats the stake nut then? I’ve not heard of that before.
Thanks!!
A stake nut is a nut that you tighten up then “stake” the top into a grove in the shaft to lock it. It’s obvious when you remove the cap.
This is a question I have often wondered about and it is, are both nuts on both front wheels a right hand thread or is one of them a left hand thread?
The hub nuts are right hand thread on both sides.
Thank you for reply, as I seam to remember on the old Mini’s one of them was a left hand threaded.
The torque setting for the hub nut is given as 123 to 160 ft-lbs, what’s the ideal setting for the torque wrench?
Anywhere inbetween, I normally go about halfway so about 140 ft-lbs in this case.
