Would make a good meet if you cant get to N.I for the spring rally. A good mix of driving roads and tight technical sections. Tom tom itineries available and the route has been done using Tulip diagrams. Run length is 113 miles and the longest section of driving will be @1h15 and 41 miles
The start point will be the Craven Heifer pub just north of Skipton off the A65 10.30 for a 11.00 start Craven Heifer Inn, Grassington Road, Skipton, Nth Yorks, BD23 3LA http://www.cravenheifer.co.uk/index.cfm
The first stop will be The Tan Hill Inn sjould be about 1h15 driving time the route will be via Hawes and J.Clarksons best bit of Uk road The Buttertubs pass we will stop for about 30 Mins and depart at @12.45 Tan Hill, Reeth, Richmond, Swaledale, North Yorkshire Dales, DL11 6ED http://www.tanhillinn.co.uk/
The route will be Via the Redmire moor and Back roads
The Main stop will be Masham at the Black sheep factory we will stop for about 1h30 and depart @ 15.15 The Black Sheep Brewery, Wellgarth, Masham, Ripon, HG4 4EN http://www.blacksheepbrewery.co.uk/
Route back will be Via Brimham rocks + Burnsal We should arrive back at the Craven Heifer at @16.15
Its a long way to the start point ,But can be done via the M65 + A56 from Manchester in an hour and Liverpool in 1h30 Even sheffield is only a 1h40
Photos…Not many and none of the buttertubs pass as I was a little busy and George was going “gigigigidittty gigigittty goo” every time Skir67 blow off whistled The craven Heffer before the start
Superb run enjoyed meeting lots of folk from far and wide, had to leave at the brewery as needed to be back,
Good job plod was office based today as there would have been at least 60 points and £1200 smackers heading the way of the yorkshire constabulary thanks to Mr Gatso!
We were the bright blue car that joined you for a while near the Tan Hill and loved meeting up with you, hope to see you all again on other runs. We have just moved to Catterick from Scotland and this was one of our first runs out since moving, we are now joined to the Yorkshire Ridings area. Thank you for making our day out wonderful!!!
