Cleaning and replacing the window cables and pulleys...
Hello. What should I  use to clean all the old gunk away from the window cables, and what should I use to grease these with after? Thanks.
Wipe down with white spirit, should clean off most of the crud. I think any sort of grease should do for a lube, lithium based is easy to find.
