Clutch fluid overflowing spraying all over engine?
Thanks all.
I spoke with the guys who did the cam belt change (amongst other work) who took the car back to check it was nothing they had caused. It turned out it was that little rubber stopper below the CAS, fooling me into thinking it was clutch fluid as it was spraying directly onto the clutch fluid reservoir.
Thanks for your help guys, I’m always learning more about these cars every time I’m on here
