Hi there,
I’ve just fitted a Cobra rear silencer to our 2019 2.0 ND. The gasket supplied is a larger internal diameter than centre pipe so I used the original. (I’ve contacted the supplier but guess response won’t be until Tuesday).
It seems ok, i.e not blowing. However I’m not convinced it looks right or is right , stupidly I can’t remember what it looked like before, I Also I checked old and new for seating in the silencer and it looked the same - same amount protruding only internal diameter different
.So before I strip it back down (car needed today) does anyone have any thoughts or pictures ?
Doesn’t look like anything to worry about there to me.
Thanks, I suppose if the new gasket hadn’t been a different diameter I wouldn’t even be questioning it. Not blowing and boss liked the sound when she set off for work.
I guess I expected the gasket to sit further inside the silencer
I have had Good-Win and Cobalt back boxes on a couple of ND’s. The interface was definitely closer with both those however if it’s not blowing I’d say there’s likely nothing to worry about.
