Anyone else had a DENIED ACCESS message, I have and am now testing this link to see if it happens again
To answer my own question, when I save it to Favourites (North Thames Region) I cannot open it from there. But I have got round it by accessing it from a link to the MX5 owners club then to North Thames, long winded and I had it working perfectly previously. Also I have cleared the IE cache as suggested by Eric and has not made any difference. So if any Site monitors or managers are reading this, what is your next suggestion please.
I had this, but found a solution that worked for me.
Once logged in (finally) LOG OUT at the top of the page . (this clears your cookie)
Log back in
Remove and replace your favourite and or home page link
You should only have to do this once on each pc that was used on the site by you in the past
No troubles for me since…
Thanks Harco, still trying, at the moment still doing it via the main site.
Contacted Martin, awaiting advice or fix.
Martin got back to me, suggested I clear cache and cookies. Did this it appeared to work until now when it would not accept my password, so have had to reset and get a tomporary password.
Testing after reset password, seems ok - FOR NOW
I`ve been getting this “Denied Access” on my work PC & assumed it was a work security setting but now getting the same on my laptop. Will try the above & see what happens.
Had the same problem cleared cache and cookies problem solved. I think clearing the cookies was the key.
Just tried this on Laptop & seems ok now. Will do same on work PC tomorow [Y] Cheers
