I’m looking for technical help or recommendations on: __Door card removal
Hello I am trying to remove my door cards, I have found the two screw behind the door lock lever and in the cup holder but I cant figure out how get at the screw in the door handle. Can any one help?
Once the screws have been removed from the door pull, cup holder and from behind the release catch, it’s just a matter of unclipping the outside edge of the panel. I would recommend using a trim tool and applying outward pressure next to each clip. The clips are quite fragile, as I’ve learnt from experience!
