I am used to doing this on Mk1 and Mk3, but recently switched to a Mk2, don’t get home from work til night, and am working by torchlight! What is the easy way to remove/replace the headlight bulb? It works on main beam but not on dip. I have a replacement bulb and can access the correct area of the back of the unit, just want quick confirmation of what to pull off lol
3 electrical connector, rubber cover and then the bulb retaining spring - in that order [;)]
Excellent - thanks! I pulled off the electrical connector last night then got confused about whether the rubber cover needed to come off - will proceed now I am reassured it does!
