Hi all, my 1990 Eunos has developed an intermitant problem. When I drop off the accelerator and drop the clutch down as I come to a junction the engine will occasionaly cut out. It seems to be worse when the engine drops from high revs. The idle drops very low before jumping back up or giving up and cutting out.
I’ve had a look through old posts and have found simular issues with the idle but nothing quite the same. Thought I’d start by cleaning the flap on the air flow sensor…any other suggestions greatly appreciated!
