NA (MK1) | NB (MK2) | NC (MK3) | |||
5 Speed | 6 Speed | 5 Speed | 6 Speed | ||
ENGINE | Sump Plug Size | 19mm | 17mm | ||
Sump Washer Part Number (Mazda) | 9956-41-800 | 9956-41-400 | |||
Sump Plug Tightening Torque | 29-41Nm [22-30ft/lb] | 30-41Nm [22-30ft/lb] | |||
GEARBOX | Filler Plug Size | 14mm Open Ended or 16mm Double Hex | 24mm | As NA (MK1) | 24mm |
Drain Plug Size | 24mm | ||||
Plug Washer Part Number (Mazda) | 9956-41-800 (2 Required for 6 Speed, 1 for drain & 1 for filler) | ||||
Filler Plug Tightening Torque | 25-39Nm [18-29ft-lb] | 27-48Nm [20-35ft-lb] | As NA (MK1) | 40-59Nm [30-43ft-lb] | |
Drain Plug Tightening Torque | 39-59Nm [29-43ft-lb] | As NA (MK1) | |||
DIFFERENTIAL | Filler Plug Size | 23mm | |||
Tightening Torque [Filler & Drain] | 39-54Nm [29-40ft/lb] | ||||
Plug Washer Part Number (Mazda) | 9956-41-800 (2 required, 1 for drain & 1 for filler) |
