Engine whine noise?
Does sound transmission related. I would check fluid level and change it if it’s not been done since new. But could be the trans oil pump worn out.
Hi,
I did change the automatic transmission fluid. The thing is when I drop into neutral it still does it and I assume the automatic gearbox is not engaged at that point.
Thanks.
It can still be the torque converter or hydraulic pump, even in neutral. You could try an additive such as Lucas Transmission Fix or Liqui Moly ATF Additive to reduce the noise but I’ve never tried this so can’t guarantee it will work.
Anyone with any other suggestions as to what this could be?
Keep posts on topic, avoid directing posts at individuals and leave the moderation to the staff here. Consider this a warning of the likelihood of a time out if it continues.
If you don’t have something constructive to add to a thread then feel free to prolong the life of your keyboard by giving it a rest.
No idea as to what it could be, but really I’d say you need either another person to do the listening to track it down while you’re in the drivers seat (or vice-versa) or one of those kits you can get with listening devices you attach to different parts of the car that you can switch between to hear where it’s loudest from and in that way track down the noise.
Put some plain water in a spray bottle, when the noise starts, spray your belts with the water.
If the noise stops you have your answer.
