Hi guys, the headlight bulb’s gone on my Eunos. It’s a 1990 model. My mate is a mechanic and, although he hasn’t inspected the car yet, he reckons that the whole headlamp unit will need replacing because it’s an import. Is this correct? Or can I just change the bulb?
Sorry if this has been asked before, any advice would be appreciated.
Just a note that Koto also do non sealed units and bulbs so its worth just undoing the three retaining screws and popping the retainer off and seeing if the bulb unit is part of the headlight or not.
Have a good look and be careful to make sure they are the retaining screws and not the adjustment screws you undo.
If you swap to standard H4’s with bulbs rather than sealed you will have better lights as the sealed are lower wattage.
