Mk3 NC 1800, Took the front off, (don’t the horns get rusty ?) fitted a MazdaSpeed cold air trunking system (similar to the K & N item) cleaned all round the front whilst the bumper assy was off and coated things with “chain lube” - leaves a film which is water & moisture resistant, then under bonnet fitted a big bore throttle body, and did a bit of tidying up, front back on, then ran it to allow the ECU to sort out the throttle body and stabilize idle, took it for a run and it picks up better and possibly accelerates a bit quicker (so the seat of my pants feel says), need to wash and polish next - perhaps tomorrow dependant on there being a big bright ball in the sky. PH.
