This is intended for information, and hopefully may be helpful to someone else. I would appreciate confirmation.
A while ago I fitted a USB socket into the speaker grille in the centre of the surface of the dash, just in front of the windshield.
I wired it into the fuse box in the cabin, situated just in front of the passenger door and used a piggy-back fuse into the AUX PWR 15amp socket.
I didn’t realise that a piggyback fuse can be inserted the wrong way round, and it does matter.
If the piggy-back fuse is inserted the wrong way round, the accessory you are trying to power may still work, but it will not be fused, and this is obviously a concern.
It’s possible to use a multi-meter to find out which side of the fuse box is the “hot side”, however I found the following very helpful.
Install the piggy-back, with its two fuses.
One of these is the original 15amp fuse, and the other is the fuse for the accessory ( in my case whatever is connected into the new USB socket in the speaker grille as above).
*If you remove only the accessory fuse
• Original circuit should still work
If you remove only the original fuse
• Accessory should stop working
If that doesn’t happen → the piggyback is reversed??
IS THIS CORRECT?
Have now turned it around, and the conditions above (*) now satisfied.
Looking for advice.
Top photo as fitted originally.
Bottom photo, piggy-back fuse turned round (180 degrees) - this is the correct direction of insertion to ensure your accessory is fused?
