Fog lamp problem
I noticed at the weekend that one of my front fog lamps wasn’t working so I checked the bulb and saw that it had blown. Today I put a new bulb in but now neither side work. I’m trying to locate the fuse but not having much luck, can anyone help?
Have you looked in the fuse box under the bonnet? Is there not one in there called FOG?
A number of cars have lost the stickey label that shows where the fuses live, have a look here for more info
http://www.mx5oc.co.uk/forum/forums/t/180.aspx
I thought that was the rear fog position, but maybe it is the front as they are factory fitted yet the rear one is aftermarket. Do aftermarket rear ones have inline fuses then? If so, then the one marked fog under the dash could be what i’m looking for.
