At crawling, manoeuvering speed with wheels on full lock, I’m getting a fairly loud ‘clonk’ from the front wheel(s) - also discernible through the steering wheel. Seems to correspond to a single wheel rotation.
It’s been too dark and wet to get under and have a proper look. I replaced ARB droplinks for MoT back in August this year.
I’m guessing there’s a fairly obvious answer - anyone?
These get to a certain point and then let go of all wear/movement potential, hence the clonk.
Hopefully the MK1. not the MK3 as control arms and joints combined and expensive on MK3?
you are going to have to get the corners jacked up and levered to confirm. Possible to get full front end off the ground and have someone turn the steering wheel to observe first hand.
I have the exact same issue on full lock (left). Have taken the car to two different garages (one of which very well known MX5 specialist) and they couldn’t identify where the noise is coming from.
