-halli-'s blue LED's
Haven’t you seen the full ensemble? Including footwell LEDs (passenger side now installed but no pics)
Just noticed that the pop-up LED isn’t on. Must have popped out of the hole.
how did you fit them in the vents they look soooo coool,
Topic split & moved to “Styling” forum otherwise original thread could go way off topic.
good point well made, in that case as above, how do you put them in the vents and also i’ve taken the hedlight adj switch out of my mk2… how do you change the bulb :S:S
I thought it had gone missing in 'tinternet ether and pearoasted it in the original topic :lol:
Original threads on the old forum
LED Phase 1
LED phase 2
On the MK1 you can route the cable behind the dash and through the eyeball vent at the back. It is held in place with pixie kisses and children’s wishes.
You will be able to see the base of the bulb holder in the switch. It’ll be a black or brown circle with a cross cut into it so you can twist it with a screw driver. Going off topic again now[;)]
