One of my Hard top rear deck Frankenstein cover, lock screws has turned off. Can these be drilled out or is just as easy to replace the whole unit and start again ? Also do the latch plates wear with age ?
Sorted. Used correct JIS screwdriver plus mole grips and WD40. Replaced the two latch plates as nylon part badly worn
