Toothpaste headlight cleaning
And the next clip shows the clear coat lacquer technique in full. Well worth a look.
There are companies that will come to you at home or work and do it for you, for a fee, of course.
They will have the correct equipment and perhaps more importantly, experience of how to use it.
Do an internet search for headlamp restoration in your area
I restored my mk2.5 headlights using Autoglym’s Headlight Restoration Kit. You basically use 4 different abrasiveness sanding papers (with electric drill), and finish up with polish. It took me several hours to do, but it worked very well!.
Check their video how to do it here: https://www.youtube.com/watch?v=OiSSEvskgHE
P.S. Make sure you use a lot of masking tape around headlights.
I refer the speaker to my earlier post of 9th August.
Prob much cheaper than a ‘kit’, as well - especially if you already have the constituent gubbins in the garage/shed
Hi, I’m a newby, and have removed clouding from outside headlamp, but the majority seems to be inside… I guess this is a whole new problem. Any advice please?
Meguiars Head light restorer kit from Halfords worked great on my sons Renault Clio comes with mop for drill follow instructions it works great
Hi folks, I have read about so many options to remove the dull aged look to the headlamps and found Solvol Autosol perfect for the job. Just use a small amount on a small area and buff up , great result !!! continued with the whole headlamp ,very happy. Only a cloth needed !!
cheers SB
