I’m looking for technical help or recommendations on: gear lever shifter and gaiter overhaul
Hi all
I’m removing a quick shift mechanism, going back to standard.
All going well, including turret oil change with 75w80.
My lever won’t go in with the click that all the you tube guides seem to achieve?
Tried a lot of wiggling!
Front groove lined up.
Here’s some action shots:
Hi, I found that the only way to get the lower boot off was to cut it off. Even then it was a tight fit. I know it slides over with a bit of oil when putting it on, but I would have a go at removing it before you place the order for the other bits, as you will probably need a new one…
I also replaced the upper nylon bush (as in one of your pics) that carries the wave washer. My wave washer was in two pieces so I needed a new one. Had to get it from Mazda; and I thought while I’m at it also get the new upper bush from Mazda.
