Hi all, looking for some help or recommendations.
I daily my Eunos V-Spec 1995 and do all the not so serious work myself, after 145k miles I’ve got rod knock and need a swap. I’ve sourced a great, like for like, low mileage engine. But garages are quoting around £600 for the job (not including the engine). I’m based around Coventry-London.
This seems a bit steep for something that I’d ideally like to help/learn on. It’s more than I was expecting, basically I can’t take the cost. The pressing matter is that I’ve only really got until late June to have it running again because I’ve just finished uni and have a job starting date.
James
Hi James
Unfortunately that is about the right amount for a mainstream garage to charge for an engine swap.
I would have thought you could find a independent garage in coventry that would do it for £400 - have you tried Walsgrave garage? Its been some while since I used them but they still have a very good reputation and fair pricing.
Unfortunately this is not a job you can really compromise with. Pay a professional with the right kit and relevant experience to fit it for you.
