Had a missfire today and pulled all the leads and plugs out to inspect without noting the lead locations [:$]
I know they connect at the plugs 1 3 4 2 (back from the radiator - from Rods manual) but what order do they connect at the coil pack (left to right)?
P.s. it is a 1.8 NA
EDIT
Just got this from Miata.net
http://www.miata.net/garage/ignition.html
and the firing order is different.
Which is correct?
3 2 1 4 left to right on the coil pack of my '91 Eunos. Hope this helps…
Thanks. Should have said it is 1.8 and Miata.net says it is 4 1 2 3 left to right They also say it is a straight 1 2 3 4 on the plug end but Rods manual says different.
Funnily enough, here’s an FAQ about it[;)]--------------
http://www.mx5oc.co.uk/forum/forums/t/149.aspx
