I wanted to respond to this earlier, however the thread is locked and I’m unable to.
@J6NGA - To help put your mind at ease, late last year I changed my thermostat after having the same issue with it sticking open and I can tell you that I had some similar concerns.
I had a bit of smoke, and quite a strong eggy smell (normally associated with a failing catalytic converter) and I was equally stressed out.
However, the advice you have been given is correct; if its been like that for years then the chances are ifs not been running as well it would otherwise.
My remedy was to buy a bottle of Forte (FORTE Specialist Petrol Specialist Injector Cleaner (400ml) Lower Emissions | eBay), put £20 of V-Power in it and spend a couple of hours giving it a really good thrashing over the North Yorkshire moors, basically redlining it the whole time between gears (I wasn’t terribly happy doing this, I don’t drive it hard usually and I felt like I was really hurting it).
However, it immediately sorted itself out… And with regards to other people’s comments about them loving a good beating, this is spot on advice - I cannot overstate the improvements I felt after a good long, really hard drive. After it had been driving around with a knackered thermostat for years it was clearly coked up and after this drive, it felt like a totally new car - it was like night and day.
My oil consumption also went down, it must have de-gunked the oil control rings too.
Give it a go and see how you get on.
**Absolutely do check the obvious things first though - custard in your oil filler cap/expansion tank and/or an obvious coolant loss as indicated by the level on the expansion tank.
