Jacking Points?
Hi
Not quite sure where to place this one, so here goes.
Where is the correct place to jack up the front/rear of my '5? I am using a trolley jack. Also where would I place the axel stands? I know that this sounds pretty basic but I have heard horror stories about people whe have jacked in the wrong place.
You should jack on the centre of the differential casing & in the centre of the front subframe. The axle stand points are inbetween the drain holes for the sills. I see a “How to jack & support your MX-5” STHT article coming on…
That would be ace. In fact, I reckon there’d be a lot of mileage in a series of short articles aimed at people who are looking to take their first steps in looking after their own MX5s.
Thats not a bad idea,i would be checking it out.
This might help [Y]
http://www.techguys.ca/howto/floor_jack.html
 There’s an article in the STHT archive, by Dr Bob. Another good reason for joining the OC.
http://www.mx5oc.co.uk/articles/viewarticle.aspx?id=15
That first article mentions putting the vehicle into 2nd - I always leave mine in either 1st or reverse when stopped, but is it better to use a higher forward gear?
 First or second both work for me. The higher the gear the further the car moves before the gears mesh
(Content deleted - posted elsewhere)
