Key!!!!
Is it just me or is the Mk3 key absolutely impossible to attach to most keyrings!!?
Am a newbie, have had my MX5 only 3 weeks and am at a loss!
HELP! [*-)]
There should be a mini split-ring that came with the key that easily attaches to normal bigger split rings.
Like this
MK3 Key fob
Nigel
Ah I see - I’ve been trying to attach a normal sized ring to it and couldn’t get it to loop back through the hole.  Assume previous owner had the same trouble as the silver coating is all chipped and marked.  Doh!
Have had a mare generally with the keys (my only grumble) as was only given one originally and had to fight tooth and nail to get a second/spare out of the dealer; neither of which had rings attached.
Thanks very much for your help, much appreciated.
Theresa
Having got your problem with the keys sorted I hope you are now enjoying the car as intended.
You should now have a smile on your face every time you go for a drive.   [:D]
