I have just removed the hard top ready for the super summer we are due. Last night after a heavy downpour the drivers seat was wet. I notice that when I drive the car in the rain there is a drip from about half way down tha A pillar. It seems a coincidence that this has started after the removal of the hard top. Any Ideas?
Hi Gary
I had a similar problem and mine was cured by replacing the catch nipples as mine were broken, cheap fix for approx £5.
Zippy. [:#]
Clear all of your drain holes and check the seal is pressing against the glass evenly. You could try my foamy tubey fix.
I’ll pm you my address so that we can sort out some of the foamy stuff if that’s ok.
