LED numberplate lights - Sorted, after a bit of a mystery......
Hi,
I managed to get LED numberplate bulbs for my Eunos (type 832 bayonet type). I bought them off ebay and they arrived yesterday, yeh! I went straight out ofit them and they didn’t fit or light up. I found the following:
1- You need to swap the polarities of the wires. I did this by unclipping the small connector at the base of the bulb holder and forcing it back on the other way round, simple! (once I figured it!!). I knew the LED bulbs work as I bench tested them with a 12v battery, that’s how I remembered LED’s are polarity sensative.
2- The LED lamp head were too big to fit through the bulb holder hole. Simple, there are 2 screws that hold the bulbholder in place, if these are unscrewed the whole holder comes out and the bulb can be pre-fitted and the holder screwed back in.
3- Not so simple, the bulbs were a little long and to get them to fit I had to take metal backing reflectors out, no issue as I just lined the inside of the hole with silver tape.
-Bulbs look good. Like the new BMW’s have! I will post pics once it gets dark…
I have just fitted LED bulbs to the sidelights and they look a thousand times better and a lot brighter.
Will be interested in seeing the pics of how they look with the numberplate.
Ady, your number plate lamp bulbs are 12v5w capless ones same as your sidelights, dont buy the ones mentioned in this topic for your car.
Not the best pic, flash bounce!
Robbie is right. You lucky people with UK cars have nice, easy, 501 wedge bulbs (same as front side lights).
I have done my fron side lights as well. Much nicer than the yellow tinged regular bulbs.
 I’m glad you managed to get them to fit in the end. They look very bright.
Hi,
They’re not too bright, I was worried they would be dazzling (about 20 LED’s on each bulb). Most of the light in the picture is from the camera flash I think.
Very pleased with the look. Would reccomend it, worth a fiver of anyone’s money IMO.
HID next I think…
 I fancy some front side-light LED bulbs - anyone got a reliable supplier at the right price (and part number)?
Ta.
Got mine off ebay for £2.99 plus P&P. They are white with 4 LED’s in each, don’t get the single LED ones, not as bright.
Maplin’s sell them, but they are £8.99 a set.
Search ebay for ‘LED 501’ or ‘LED side lights’ and loads will spring up.
ah they look good … and cheers for the pointer on which ones I need.
Just been on ebay and grabbed some of the same ones I bought for my sidelights.
They have 6 LED’s per bulb so should light up quite nicely. [H]
This was really useful thanks! Fitted these - not too wide or long. Look great!
