Mazda MX-5 Miata Mk4 ND 2015-2024 Red LED Boot Lid Strip. Plug & Play
Thanks Ian.
As you probably noticed I taper the plug so it will go through the grommets but it takes a bit of twisting and pushing. Took me a lot of searching to find ‘rubber’ grommets that are actually made of rubber rather than slightly flexible plastic. As I said in the instructions holding the back of the plug and twisting the grommet on to it is the way to go.
I’m aware of another similar product on the market which in the instructions suggests using the existing grommet and plastic plugs with a slit cut from the edge using a craft knife and sliding it over the wire. Nothing to stop anyone using that method with my kit but personal opinion is that a grommet with just a hole the same size as the wire is better.
Doesn’t look quite as bright on the Machine Grey. Mine is Soul Red and the second prototype kit was on a Soul Red Crystal car. Maybe a thin strip of a pale coloured tape along the inside lip would do the trick if you want it a bit brighter. The LED strip is 120 LEDs per metre so pretty much blinding when viewed directly!
Congratulations on being first to post a picture and review.
Thanks.
