Just back! And the news is… the rattle is gone! Got back to the garage and she’s purring like a kitten again, really nice and quiet! Thanks again for the advice guys, spot on as always.
So, seeing as I’m feeling a lot happier, thought I’d take a quick photo of the almost finished wheels (3 finished, 1 still to go into lacquer and 3 wheel caps to go into lacquer)
Ignore the tyres as these are getting binned
Really pleased with them, the finish looks as good as new. Hope you like! Can’t wait to get new tyres and get them fitted.
Having owned an MX5 MK1 in irregular use since 2002 have got used to the rattle and its temporary nature.
Some claim to have permanently cured it with filter/oil change but I have always accepted it as an inevitable sign that I am not driving her frequently enough:-)
I have gotten into a habit of when I’m parking up, letting the engine tick over for a little while, allowing the engine to cool. Seems to work with respect to HLA. Otherwise, generally its a sign of a cheap 10W 40 oil needing a change. I don’t think thats a bad habit.
Note on “Mazda oil filters”; the ones supplied by Mazda Europe are French (Puralator) and smaller, than the ones originally fitted in Japan. Supposedly higher tech. The trick was to get a filter fora Mazda MX6 or similar; its Japanese made.
However, I’ve for many years used whatever filter the Factors have.
If its rattling badly after being laid up, can be a sign of a blocked oil pump strainer. Revving the engine (going for a drive) as a “fix” can wreck it. Bit more of a harder rattle.
Well, going by the level when I bought her a few months ago, she’s covered around 400-500 miles (estimate, may be more may be less) and the level when checked the other night is the same, so she hasn’t used any oil which is good. Deffo going to get her an oil and filter change as soon as though as the oil does look like it needs changing soon. Not the worst I’ve seen but she deserves the best.
Unfortunately due to circumstances spending has to stop for the time being. So the service/new tyres will probably need to wait till after the new year now. She probably won’t be out very often now anyways seeing as dreaded winter is almost here.
Not necessarily. Happened to the motor in my 96, 10+ years ago. Difficult job, but not game over. Game over if you rag the engine in a vain attempt to make it go away.
It would be a rare and unfortunate occurence. Autolink are giving 1.6 and 1.8 strainer systems away at a tenner which tells me that a replacement strainer unlikely to be required. This does not fully answer the question though as it looks like an item that is more likely to be removed, cleaned up and refitted.
From my experience the 1.8 engine fails suffers far more than the 1.6. Crank failure from low oil(as burns more oil) and sticking oil rings from being cooked(MK1/Eunos).
Would be interested to know if racing teams/engine rebuilders give the strainer any attention.
Ragging the engine is a waste of time with the typical top end noise - it just goes in its own good time after a couple of minutes of driving on my MK1.
An oil change/better quality oil will improve the situation but if car undriven for weeks as mine is unlikely to completely disappear.
Not that uncommon if you look. And the issue is NOT the strainer failing. Its an issue of the strainer blocking, in cars that have been left standing for a while; not at all unusual for MX5s. The repair involves a new oil pump. I imagine a clogged strainer can be cleaned out of the engine; its just a tube with a mesh strainer. When the strainer is blocked, the oil pump is toast.
You never heard of plenty of “MX5 experts” recommending an “Italian Tune-up” to sort out HLAs?
I’m guessing Autolinkuk can’t give these things away because only a dunce would strip down an engine and use scrapyard parts, when new parts are inexpensive. Why would you go to the bother to fit a new oil pump, but not bother to clean the strainer with £5 of kerosene?
As I suspect race car operators rarely have a car sitting with sludgey oil, I doubt its an issue. Race teams I know will rebuild the engine over the off season, replacing oil pumps etc. The OP’s car has a certain level of unknown history. Garages can be lazy; even a well known MX5 specialist is known to cut corners by using a pump to change oil, rather than a proper drain.
Unkown, fresh off the boat JDM motor, sludgey
Its seems sludge build up is not necessarily due to infrequent changes; sludge build up can be a product of engine design (some engines will cook the oil in the head after shutdown) or poor grades of oil (how many 20 year old MX5s have existed on a diet of Tesco’s finest). Heat is a factor. So a car cooked on a track will rattle like a good un if shut down quickly. Oh, and to include your favourite bete noire, oil impregnated air filters have been implicated.
And HLA rattle is caused by, what for it, a blockage due to sludge. The B6 suffers from that quite a lot, the BP-ZE a bit less so (in my completely meaningless and worthless 20 years experience of these cars). But there are enough recorded instances of strainer blockage on the BP to be a factor worth considering, and not simply dismissed out of hand because you have never seen it on any 1.8 you have owned.
Interestingly, the 2001 BP engine included headgasket changes that reduced temperatures on 1 and 2.
Oil pumps, in normal service, should last the lifetime of the car. But MX5parts must sell enough to list them as a part. Wonder why that is…
I have looked and not much evidence of this being a common problem
No! and bad advice which should be ignored from my personal experience of this problem
Agreed - not a lot of point.
It’s the 1.6 and pretty sure Dave has taken the cam cover off already - would expect it to have been very clean.
Never seen any sludge buildup in engines I have worked on - would be appalled to see a situation like that and would expect lots of associated problems. You don’t agree with the oil impregnated filter theory and MAF damage but lots of evidence indicates you and the K&N PR department are misguided. Certainly room for debate as I remember from the pertinent thread we clashed on.
No sludge in my engine but HLA rattle - strange that! Never owned a 1.8 MX5 as it goes but they seem to have a lot more oil related engine problems than the 1.6. Aware of that from customers experience and engine demand. If you thought for one second that your experience on these cars was meaningless and worthless, you would not argue your points so much. It should be possible for us to debate technical matters without this sort of diatribe. Dave has a 1997 1.6 - what is the point of worrying him with the unlikely source of a standard top end rattle, especially as he took our advice and rattle now gone - well what a surprise that was?
One old, dodgy review of the £166 pump - that tells me these do not sell in big numbers.
Had heads & cam covers off both our 5’s over a “paltry” 15 years of joint ownership for a variety of reasons including cam covers.
HLA clatter occasionally on the Mk1 1840cc with both it’s mills, but zero sludge like the photos …mostly the usual staining/varnish patina you would expect.
Why both engines on the Mk1? Simple, ragged it stupid at Croft and cracked a couple of oil rings. Fresh oil etc before I went, but it is an inherent weakness.
Mk2.5’s bits were pretty pristine at it’s cambelt change as well.
Popped a new cam cover gasket on it last year, looked still brassy & clean in there.
Mind you, it’s only done a lowly 101,000 miles so barely run in…and loves an Italian as much as I do whereupon the next morning it certainly starts as usual with a bit more brio and settles down to a more even and silent tick-over following a week or so of urban boredom. SS Exhaust sounds crisper as well. It is 100% oil tight, ticks over as new and still gives around 34mpg, Spins as sweet as a nut. After…15 years of “cleaning it out” once every couple of weeks or so. Commonly known as…an Italian Service. Perhaps also why I only had to renew it’s rotors & calipers after…98,000 miles!
They are, after all, small revvy twin cams…so use it.
Both cars get 5k oil changes, main dealer filters, and regular daily use.
Well, the Mk1 is SORN awaiting a full metal resto…after which it’s getting the “new” engine fully serviced to include belts and any other stuff not 100%
Meantime, it gets started up once week and revved once fully oil-warmed up to 4/5k for ten minutes or so.
Seems to be the mantra. Regular use, regular oil services.
Modern mainstream oils are pretty epic at keeping engines clean.
Thanks for the comments and info guys. I’ll deff be giving her a good service and have a good look over her and see what needs replacing… Been out to garage tonight and fired her up, running nice and quiet, no rattles this time and really smooth. Hopefully an end to the rattle!
Out for a run in Mindy today seeing as the sun was out!
Came back and decided to get the 3 wheels that were done finally fitted. Still got 1 wheel and 3 centre caps to go into lacquer tomorrow then grt them all fitted. Love they way she looks with these done in white, kinda retro look. Still on the crappy tyres for now (managed to get most of the paint off them), new tyres after the year.
