personally I think you should go with the mk3.75 mazda sport springs and dampers.
the car will be low enough to look ok, handling and comfort is great and decent ride height that wont cause you much trouble on the road. Note I mentioned the 3.75 as the early NC’s suspension specs use relatively higher springs even if the suspension swing arms and linkages are identical.
This is what I said at a different post about the Meister’s and although I never owned them I still rate them to be on the lower end of the band for suspension manufacturers.
