Hi, my headlights don’t pop up when using the light switch but do when using the push button. Can anyone help at all?
Hi there, not had the problem myself,
but a couple of links that may help you out
Thanks I’ll check them out
Thanks again but I did finally resolve the pop ups and flash to pass by replacing the retract relay, the one under the steering column to the right. Much relief.
