Hi all,
A quick question really…
In the middle of a turbo conversion and looking to use AN fittings where possible. Will be converting all the fuel lines to AN (I have a Ext. regulator and Raduim fuel rail), the turbo oil and water lines, etc.
I have the DaveFab catch can which are 1/8 NPT and I’d ideally like to convert the feeds into the CAM/rocker cover to AN as well. If anyone has done this before;
what size did you tap into the Cam cover breather ports?
I presume you just pulled out the existing barb fitting on the EXH side?
Any help is greatly appreciated.
Best regards.
Mike
