Hi I just got some front factory fog lights for my mk1 and I need the wiring harness that goes from the fogs the the plug in the engine bay. Does anyone have one for sale?
Welcome Ford79.
Bit like hens teeth I am afraid, they do turn up occasionally on auction sites or you could make your own, note that there is also a relay involved. If your car has the connector by the righthand wing it probably also has the connector behind the dash for the twin HRW/Fog Light switch available on order from Japan.
Good luck
Dave
I might have to make one up not sure what plug is on the fogs though. Would rather not cut the plugs off the fogs to fit new. HRW and fog switch sounds ideal. I had planned on a mk2 front and rear fog switch
