Mk3 1.8 Engine rebuild due to oil usage as piston ring clogged up
Hi
I recently rebuild my friends 1.8 engine for him as it was using a lot of oil, no engine knock as he was good and just kept putting oil in.
The rebuild showed the known issue with the piston oil control rings and hopefully we have modified the piston to help stop this happening again.
been watching you on youtube
