Be very careful with the studs/nuts which hold the arb bushings as they are made of chocolate and need very little torque to snap.
An M10 x 1.25 pitch die nut ( available from £4 up depending on quality) will make the job easier as you can run it down the exposed threads on the drop links before trying to undo them. They often jam after loosining a bit which makes them awkward to get off.
That’s great, thank you. I’ll be sure to follow all the advice.
