Hi all, not really a request just a comment. Had our ND for 2+years and needed to put some air in the tyres, looked everywhere for the 12volt output socket and drew a blank so ended up going onto 'tinternet so discover that it is “buried” in the righthand side passenger footwell, almost did my back in trying to find the bl@@dy thing!
I always keep the manual in the car, it’s got a lot of useful info about, bulbs and other breakdown info.
No use sitting on a shelf at home. Then when you sell the car, it’s still on that bookshelf, and the new owner has to buy a new one.
I know there’s not a lot of storage in the ND, but it’s fairly small.
I know you can usually get online, but if you get stuck without a phone signal…
I showed the salesman where it was when I was looking over the car. I crawled under and over it with a torch and checked it over but I knew where everything was first.
There is some ‘secret’ storage behind the seats on the Mk4, two cubby holes with a pull off flap on each. I keep my handbook in one and the tyre repair/inflator in the other.
Yeah it’s proper buried, unilluminated and damn near invisible when the cover is over it.
Fortunately I’ve found the USB sockets by the centre console provide enough juice to power the dashcam and charge a phone, despite only being 500 mA a piece, so I only have cause to use the 12v cigarette lighter socket when inflating my tyres (since Sainsbury’s stopped doing air for free, curse them!)
I did use the socket for 2 dashcams but now run both from Garmin’s odb power cable with built in timer and battery protection, phone charges from CarPlay adapter very quickly and less wires to see or get loose in the socket.
Yup. I’d have sat those salespeople in a locked room with an owner’s manual each for two hours. Then have them spend an hour driving the car.
One thing I used to do, when the car the customer was buying was in stock, so the handbook was with it, was to give the customer the handbook at point of sale so they could read up before collection. Then they still used to get a one hour handover.
