Asst mk1 and mk2 parts here. Lot jap eunos parts also incl lots clocks in kms. Also Rs type clocks in kms but with 6 oclock dial position
Hi, do you have a indicater / wiper switch with the indicator on the right, to fit a MK2.5? I understand that the late MK1 will fit?
Thanks,
Hi. I need to check but I think late mk1 ,although look same, may have different connectors
I should have mk2 to might be nearer the type. Any pic of your connector? WhatsApp? 00353 86 8226506 if its easier
This is from jdm mk2 mx5 1999
Will check.
Thanks,
